PLC S7-200 CPU 224, Output Relay
		Tên hàng hóa: PLC S7-200 CPU 224, Output Dry contact
Mã hàng hóa: UN 214-1BD23-0XB0
Mã lưu kho: UN 214-1BD23-0XB0
Nhà sản xuất: Unimat
Xuất xứ: China
Bảo hành: 3 năm
Tính năng hàng hóa:
Dùng thay thế cho S7-200 của Siemens, có tất cả các tính năng của S7-200 Siemens thậm chí vượt trội hơn với 2 cổng truyền thông. Dùng tương đương mã hàng của Siemens là 6ES7 214-1BD23-0XB0.
	Trích dẫn:
			Function Description:
1、Compatible with Siemens’ s7-200 instruction set.
2、UN software based on Siemens Step 7 MicroWIN, so, Step 7 microWIn can be download to UN PLC( for Non-wizard generated code), no need any modification the program.
3、Add one more additional PPI port, then can communicate with HMI and Programing cable at the same tiem, and perform PPI and Modbus at the same time.
4、High speed instruction performance, each Boolean execution speed is 3 times of Siemens, suit for fast, smooth and stable PID adjustment.
5、Long time power failure remained, can record data for 10 years without battery.
6、Replace Siemens cpu224 directly.
7、Support Siemens Digital, Analog and EM277 expansion Modules, and support Siemens EM277 standard V zone communication.
8、High scan speed of External expansion Module, then provides a shorter scan cycle and ouput speed than Siemens external expansion module, improve the rate of reaction of the equipment.
9、Later UN program software, will perform more convenient communication set.
- Program memory size With run mode edit: 25K bytes
- Data memory: 20480bytes, Backup keep over 10 years
- Local digital inputs: 14 inputs (6 HSC), PNP/NPN, 30K Hz (Single phase), 20K Hz (Two phase)
- Local digital outputs: 10 outputs, Dry contact
- Ports: 2 RS-485 ports, within1standard PPI port
 Giá bán: 4.000.000vnd/cái
Hàng luôn có sẵn số lượng lớn.
http://i45.fastpic.ru/big/2012/1015/...44d88ca148.jpg
