HMI (Human Machine Interface) FE1043E, Display: 4.3" STN monochrome
Thông tin tổng quan về sản phẩm:
Feature:
* ARM CORTEX-M3 high speed 32 bit RISC CPU.
* 2 Serial Ports. (2 cổng truyền thông)
* USB Downloading configuration program. (Download chương trình xuống HMI bằng cáp USB)
* E series has Encoder input. (có núm xoay giống dạng của biến tần Telemecanique, Mitsubishi)
* Offline simulation. (Hỗ trợ mô phỏng Offline ngay trên PC, không cần phải có HMI)
* Support TTF fonts, support multi-language.
* 8 level user password. (8 cấp bảo vệ bằng password)
* Support MPI. (hỗ trợ MPI)
Thông tin chi tiết sản phẩm:
Trích dẫn:
Type: FE1043E
Hardware:
Display: 4.3" STN LCD
Resolution(WxH): 192×64
Colors: Mono(yellow-green back light, black font)
Brightness: 60 cd/m2
Back Light: LED
Back Light Life Time: 50000 Hrs
Touch Panel: N/A
CPU: 32 Bit 72MHz ARM RISC
Memory: 128K FLASH
RTC: Build in
Ethernet Port: N/A
Encoder: Yes
Metal Dome Foil: 19 Keys
USB Port: 1 USB Device Port
Program Download: Through the device USB port
Com Port:
COM0:RS232/RS485/RS422
COM1:RS232
Electrical Specifications:
Power Consumption: < 4W
Input Power: DC 12/24V,Input Range:DC 9V~36V
Power Protection: Isolation Transformer
Permit Power Lose Time: < 5 mS
CE & ROHS
EN61000-6-2:2005,EN61000-6-4:2007,
ROHS
Surge Immunity:±4KV, EFT:±4KV;
ESD:4KV, Air:8KV
Environment Specifications:
Operation Temperature: -10~50℃
Storage Tepmerature: -20~70℃
Operation Humidity: 10~90%RH(No condensation)
Vibration Endurance: 10 ~ 25 Hz (X、Y、Z 2G/30Min)
Cooling Way: Natural air cooling
Others:
Protection Structure: Front IP65(with NEMA panel),Back IP20
Mechanical Structure: ABS+PC
Panel Cutout(WxH): 165mm×86mm
Out Size: 185.8mm×96.2mm×35.6mm
Weight: Appr. 300g
Một giải pháp thay thế quá tốt cho con TD200, OP320, OP325, MD204, OP3, OP73 micro, SH-300, NT11, LS XP10, KV-D30, NT2S-SF122B-EV2, NT2S-SF121B-EV2 , XBTN401, XBTN400, XBTN200, nói chung là text display :-*
Ngoài ra còn hỗ trợ nhiều hãng PLC
Giá: Liên hệ để có giá ưu đãi nhất
Hàng luôn có sẵn số lượng lớn
Bảo hành 12 tháng
Hỗ trợ lập trình khi mua sản phẩm
http://i45.fastpic.ru/big/2012/1016/...a19d5e58dc.jpg
http://i45.fastpic.ru/big/2012/1016/...4accdcf3f1.jpg
http://i45.fastpic.ru/big/2012/1016/...2cd0435714.jpg
