tuanminhplc08
chào A Cường cho em hỏi tí :em dùng win 7 32bit thì dùng phiên bản Emulator nào được anh.em cài bản V16,v17 đều không đươc.
Win7 32 bit bạn tham khảo bên dưới nha.
System Requirements:
Base Platform Requirements:
* Intel Pentium 4 1.6GHz (single core, dual-core, and hyperthreaded CPUs are supported)
* A minimum of 1 GB of RAM
* 64 MB of free hard disk space per controller instance (or more based on application requirements)
* 800 X 600 video resolution
* Any Windows-compatible pointing device
Operating System:
* Microsoft Windows 7 Professional
* Microsoft Windows Vista Business with Service Pack 2
* Microsoft Windows XP Professional with Service Pack(SP) 3
* Microsoft Windows Server 2008 Standard with SP 2
* Microsoft Windows Server 2003 R2 Standard with SP 2
This version of Emulate 5000 software is expected to operate correctly on all other editions and service packs of the following operating systems, but has not been tested:
* Emulate 5000 is supported for 32-bit operating systems(x86). Emulate 5000 is not supported for 64-bit operating systems (x64) and has not been tested in this configuration.
* Emulate 5000 versions earlier than version 19 are not supported on Microsoft Windows 7 operating systems at this time and have not been tested on those operating systems.
* Emulate 5000 versions earlier than version 17 are not supported on Microsoft Windows Vista operating systems at this time and have not been tested on those operating systems.
* Running Emulate 5000 software in conjunction with Fast-User Switching is not supported. Running Emulate 5000 software in Safe mode is not supported. Running Emulate 5000 software via Remote Desktop is not supported.
* Starting with version 18, Emulate 5000 does not support Microsoft Windows 2000 or earlier operating system. Emulate 5000 has not been tested on operating systems running on virtual machine.
Product Revision Information:
* RSLogix Emulate 5000 Version 19.01 (CPR 9 SR 3) requires the following:
* Software Product Compatible Versions:
* RSLinx 2.57.00 or higher
* RSLogix 5000 v12.00 (or higher)
Note: To emulate a controller that has been released with a specific version of RSLogix 5000, the matching version of RSLogix 5000 is required. For example, if you want to emulate a v19 controller, you must use RSLogix 5000 v19.
good luck.
Dear Mr Cuongvcs!
Cách Activation RSLinx Classic sao vậy anh? mong anh chỉ thêm cám ơn anh!
vodinhhinh
Dear Mr Cuongvcs!
RSLinx Classic 5.7 trở xuống thì không cần action đâu bạn ạ.
good luck.
các bạn ơi cho mình hỏi, mình cài rslogix 5000 v.16 này nhưngg đến đoạn crack như bác " vodinhhinh" up cái này
http://www.mediafire.com/?mritu9bivbc7m2o
mình cài trên win ảo xp sp2 32bit , win thật là win 7 64 bit
lỗi vậy đó, mong được giúp đỡ
http://www.mediafire.com/?mritu9bivbc7m2o, nhưng tới bước kế cuối thì ko đc, nó bảo ko tìm đc ổ đĩa
hoặc bác nào có key và seria cho mình xin. thanks
Bạn có thể up lại hình được không ? nhỏ quá nhìn không rõ là lỗi gì .
thanks.
Dear haivannguyen2511!
bạn cứ move vào ổ D hay E gì đó, xong từ ổ D hay E move vào ổ C thử xem, mình đã làm thành công nhờ Mr Cuongvcs hướng dẫn, file hướng dẫn đó là của Mr cuongvcs share cho đấy, mình up lên mediafire cho các bạn dễ load thôi.
mình up lại hình nek, chẳng bit sao làm hoài ko dc, như bác vodinhhinh up lên mediafire cách crack rất đày đủ
nhờ mấy bác....
nếu hình nhìn ko rõ thì nó hiện thế này " Driver not ready or target disk is unsuitable", đó nó hiện vậy đó.....
Múi giờ GMT +7. Bây giờ là 03:44 AM.
