					GP-Pro EX Ver. 2.7 new
							GP-Pro EX Ver. 2.7
File Name disk 1:Size: 575,869KB
File Description [Disk 1 Description]
- GP-Pro EX Ver. 2.7
- Transfer Tool
- Installation Guide
- Project Converter
- Pass Through
- Pro-face Converter
[Disk 2 Description]. size 265,112KB
- WinGP
- Movie Converter
- GP-Viewer EX
- Camera-Viewer EX
- Data Copy Tool
- GP Remote Printer Server
* For more information about each tool, please refer to follows.
Product Page "GP-Pro EX"
New Features of Ver. 2.7
[Support of New Models]
- GP-4104 is added.
- PS-4*00 is added.
[Support of New Features]
- Indirect Specification can be made in Value Range and Position Range for
Position and Rotation.
- While Window Screen is displayed, the switch on the back can be locked.
- Indirect Specification is available for Sampling Frequency.
- Date format settings can be made when CSV file is output.
- Image font is available in text screens.
- Anti-aliasing smoothes out rough edges of characters, beautifying their
look in text drawing and switch labels.
- When USB keyboard is connected, the input order can be changed using the
up/down keys.
- Index files can be created in on-line mode when the CSV Data Transfer
feature is used.
- 4096 colors switches/lamps and 4096/65535 colors plates for Data Display
are added.
- Subnet mask address's input control of IP address specified off-line is
cancelled.
- The number of symbols to be registered is extended to "10000".
- Indirect Specification is available for the unit number in Device/PLC
Settings.
- Bit length (16/32-bit) can be specified on an address basis.
- Function that can copy the CF card/USB memory files is added.
- Area to input the trigger condition expression can be enlarged.
- Mark screens and library parts, which are created with GP-Pro/PBIII
C-Package, can be converted.
- Feature to output the result after project data (which is created with GP-
Pro/PBIII C-Package) is converted is added.
- Alarm message using the text table can be imported/exported.
- Models can be changed from GP3000 to GP4100 series.
- Master I/F units for LT3000 (from Anywire) are available.
- Remote I/O for FLEX NETWORK (from M-System Co., Ltd.) is available in the
GP3000 series.
- Image can be displayed by connecting a Cognex camera.
- New Drivers
- Mitsubishi Electric Corporation FX Series Ethernet
- Siemens Building Technologies SAPHIR SIO
- Yamatake Corporation MODBUS TCP Master
- Yamatake Corporation MODBUS SIO Master
- Cognex Corporation In-Sight Vision Systems
- GP4100 series SIO is supported.
- CHINO Corporation Temp. Controller MODBUS SIO
- Fanuc LTD. Power Mate Series
- FATEK AUTOMATION Corporation FB Series SIO
- Fuji Electric Corporation MICREX-SX Series SIO
- Fuji Electric Systems Co.,Ltd. Temp. Controller MODBUS SIO
- Fuji Electric Systems Co.,Ltd. INVERTER SIO
- Hitachi IESCo.,Ltd. H Series SIO
- Hitachi IESCo.,Ltd. Inverter ASCII SIO
- Hitachi IESCo.,Ltd. Inverter MODBUS RTU
- IAI Corporation ROBO CYLINDER MODBUS SIO
- IAI Corporation X-SEL Controller
- JTEKT Corporation TOYOPUC CMP-LINK SIO
- KOYO ELECTRONICS CO., LTD. KOSTAC/DL Series CCM SIO
- LS Industrial Systems MASTER-K Series Cnet
- LS Industrial Systems XGT Series Cnet
- RKC INSTRUMENT INC. Temp. Controller MODBUS SIO
- RKC INSTRUMENT INC. Temp. Controller RKC SIO
- Sanmei Electronics Co., LTD Si/CutyAxis Series SIO
- SHINKO TECHNOS CO., LTD Controller SIO
- Yamatake Corporation Digital Controller SIO
- YASKAWA Electric Corporation Inverter/SARVO SIO
- YASKAWA Electric Corporation MEMOBUS SIO
- YASKAWA Electric Corporation MP Series SIO(Extension)
- YOKOGAWA Electric Corporation Personal Computer Link SIO
- Function Version Upgrade Driver
- Mitsubishi Electric Corporation FX Series Computer Link
- Serial multilink function is supported.
- Mitsubishi Electric Corporation A Series CPU Direct
- Internal relay/link relay accessible range in universal model CPU is
supported.
- Internal relay accessible range in Q172DCPU/Q173DCPU is supported.
- SRZ Series is supported.
- Rockwell Automation EtherNet/IP
- Custom string data type is supported.
- Add-On-Instruction data type is supported.
- L5K file where 1769-L23E-QB1/L23-QBFC1/L23E-QBFC1 module is specified
is supported.
- YASKAWA Electric Corporation MP/SARVO Ethernet
- Sigma-V Series is supported.
- Device/PLC Data Copy Tool
- Register information transfer can be selected in loading data.
- Transfer of MECHATROLINK-III settings is supported.
- OMRON Corporation CS/CJ Series EtherNet/IP
- Copy from Another Project is supported.
- Address auto allocation is supported.
- "Automatic match in tag address" is supported.
- Tag inconsistent error display timing is changed.
- Output of the tag check error list is supported.
- Maximum connection unit number is extended to "31 units" for 1 port.
- Hitachi IES Co.,Ltd. Inverter MODBUS RTU
- WJ200 is supported.
- Siemens AG SIMATIC S7 MPI Direct
- EM277 connection is supported.
Fixed Defects from Ver. 2.6 Please see V270000_FixedDefectsList_eng.txt
Download at   http://automation.9forum.info/f23-software
or
Disk 1
http://zpag.es/30yM
http://zpag.es/30yN
http://zpag.es/30yO
http://zpag.es/30yP
Disk 2
http://zpag.es/30yQ
http://zpag.es/30yR
Serial no
http://zpag.es/30yS
						Lần sửa cuối bởi ibmacer, ngày 06-22-2011 lúc 06:00 PM.
							Installation (These files are self-extracting.)
*Prior to installation, be sure to close all software applications that are running.
[Installation of GP-Pro EX Ver. 2.7 ]
1. Click the above file "GPPROEX270000D1.exe" to download the file to the desired folder.
2. Double-click the downloaded file "GPPROEX270000D1.exe".
3. The following screen will be displayed, click the checkbox of "Not Input Serial / Key Code (", and then click "Next". (If you enter your serial / key code, the software will be fully functioned.)
4. Follow the instructions given.
[Installation of Pro-face Converter]
To install Pro-face Converter, please follow the procedure below.
Failure to follow the procedure will lead to an installation failure and display the message, "Please insert CD of Pro EX Editor in the CD drive."
Double-click the GPPROEX270000D1.exe file.
Open the GPPROEX270000D1 folder that is created in the same location as the EXE file.
Copy the file, ABS.sys, from the folder to the root folder (C:\).
Double-click ProEX_Setup.exe to start the installer, and select Pro-face Converter.
After installation, delete the ABS.sys file.
PC Windows® PC/AT compatible machine
OS Windows® 2000 〈Service Pack 3 or later〉
Windows® XP Home Edition, Professional (any SP)
Windows Vista® Ultimate, Home Premium, Home Basic, Business (any SP)
Windows® 7 32bit Ultimate, Enterprise, Professional, Home Premium, Home Basic, Starter (any edition)
* For the installation of this product, Administrator rights are required.
* Supporting of GP-Pro EX for Microsoft Windows® 7
CPU Windows® 7/Vista®: Pentium®4 1GHz or greater
Other than Windows ® 7/Vista®: Pentium® III 800MHz or greater (Pentium®4 1.3GHz or greater recommended)
Resolution SVGA 800 × 600 or better (256 colors or greater required)
Memory Windows ® 7/Vista®: 1GB or greater (2GB or greater recommended)
Windows ® 7/Vista®: 512MB or greater (1GB or greater recommended)
Hard disk space 720MB or greater * Free space necessary for installation.
Language Software Menu English/ Japanese/ Korean/ Chinese (simplified/traditional)/
German/ French/ Italian/ Spanish
Languages that
Hardware can Display
English/ Japanese/ Korean/ Chinese (simplified/traditional) / Cyrillic/ Thai
* For languages other than English / Japanese, FEPs and fonts for these languages should be added.
FEP for languages Those supported by OS described above
Other .NET Framework Ver. 2.0
* .NET Framework 2.0 or later will be installed automatically.
Microsoft® Internet Explorer Ver. 6.0 or later
Adobe Reader® Ver. 6.0.2 or later
Mouse (absolutely necessary), CD-ROM drive (necessary only for software installation) and printer (supported by the OS above)
An environment where you are connected to the Internet
* Only necessary for online user registration and online update service
* Please address inquiries about the site license to a sales representative.
* A USB port or Ethernet port is required to transfer screens on a PC.
Transfer Tool (Required for screen data transfer from a PC that does not have GP-Pro EX installed)
OS Windows® 2000 〈Service Pack or later〉
Windows® XP (Home Edition, Professional)
Windows Vista® (Ultimate, Home Premium, Home Basic, Business)
Windows® 7 32bit (Ultimate, Enterprise, Professional, Home Premium, Home Basic, Starter)
* Support of GP-Pro EX for Microsoft Windows® 7
CPU Windows Vista®: Pentium®4 1GHz or greater recommended
Other than Windows Vista®: Pentium® II 266MHz or greater recommended
Memory 128MB or greater (512MB or greater recommended)
Hard Disk Space 135MB or greater * Free space necessary for installation
Other Mouse (absolutely necessary), CD-ROM drive (necessary only for software installation) and printer (supported by the OS above)
OS Windows® 2000 Professional (Service Pack 4 or greater)
Windows® XP (Service Pack 2 or greater)
Web Server
OS Windows® 2000 〈Service Pack 3 or later)
Windows® XP〈Service Pack 2〉
Windows Vista® (Ultimate, Home Premium, Home Basic, Business, Enterprise)
Windows® Server2003 〈Service Pack 2〉
Supported browser Microsoft® Internet Explorer ver.6.0 or 7.0
Display resolution XGA 1024 × 768 or greater
GP-Viewer EX
Windows® Server 2003 〈Service Pack 2〉
* For installation and use, the license is required. Purchase the license separately. Please contact your local Pro-face distributor.
WinGP for IPC
OS Windows® 2000 Professional 〈Service Pack 3 or later〉
Windows® XP Professional
Windows® XP Embedded
Memory 256 MB or greater (512 MB or greater recommended)
産業用コンピュータの操作画面をGP-Pro EXで作画 IPCランタイムエンジンWinGP
WinGP for PC/AT
Main memory Windows Vista®: 1GB or greater (2GB or greater recommended)
Windows Vista®: 512MB or greater (1GB or greater recommended)
CPU Pentium®M 1GHz or greater is recommended
HDD 200MB or greater
OS Windows® 2000 〈Service Pack 4 or later〉
Windows Vista® (Ultimate, Home Premium, Home Basic, Business, Enterprise) 32bit
Display resolution SVGA 800 × 600 or better
RPA (Remote PC Access)
OS Visit http://www.uvnc.com/
Other GP-Pro EX (Ver. 2.0 or later)
RPA Keycode (EX-RPA)
Ultra VNC Ver. 1.0.2 should be installed on the PCs on the server, LAN cable, HUB (Commercially available).
* Connect one server to one GP.
Page Top
Ladder Monitor
Model
EX-LADM-MIT-Q02 EX-LADM-MIT-A01 EX-LADM-OMR-CJ01
Supported
PLC Mitsubishi Electric Corporation
Q series
(CPU/ Ethernet) A series
(directly connected to CPU/ Computer Link) CS/CJ series
(Ethernet, HOST Link)
PC Windows® PC/AT compatible machine (Use of a CF card is required, when installing.)
Other CF card with 100 MB or greater free space CF card with 256MB or greater free space
* For installation and use, the above licenses are required. Purchase the license separately. Please contact your local Pro-face distributor.
Movie Converter
Windows® XP (Home Edition, Professional)〈Service Pack 2 or later〉
CPU Pentium® III 1GHz or greater is recommended
Memory 512MB or greater
Hard disk space 60MB or greater * Free space necessary for installation
Windows® Media Player 9.0
Direct X9.0c
Movie files that can be converted with the movie converter are different depending on the PCs used for conversion. Some codecs are equipped as standard in video/audio players such as Windows Media Player. When installing the movie converter in an environment just after purchasing a PC, you can convert video files described above to SDX. For movie files that cannot be converted to SDX, you may be able to convert these files by installing their codecs separately (*).
File format (Extension) Video codec Audio codec
AVI Uncompressed (RGB) Uncompressed (PCM)
AVI DV-1 DV Audio
WMV WMV9 WMA9
MPG MPEG-1 MPEG-1 Layer-2
* In order to convert movie files, first, you need to install the codec of the movie file to be converted on a PC for conversion. We have confirmed the conversion of the following movie files to SDX on a PC with Ulead Video Studio 9 installed.
AVI DV-2 DV Audio
MPG MPEG-2 MPEG-1 Layer-2
ASF SD-Video (MPEG-4) G.726
* Ulead Video Studio 9 (http://www.ulead.co.jp/product/videostudio9/)
Camera-Viewer EX
OS
(except for 64-bit OS)
Windows® XP (all editions, SP2 or later)
Windows Vista® (all editions, SP1 or later)
Windows® 7 (all editions)
Windows® Server 2003 (Standard Edition and Enterprise
Edition, SP1 or later)
Windows® Server 2003 R2 (Standard Edition and Enterprise
							Bạn ơi, có thể giới thiệu sơ dùng tiếng Việt được không?
Đọc vô, thấy ngộp quá, còn down gập vài khó khăn, bạn có thể dùng mediafire up lên giúp aem với.
							upload lên mệt wa, mấy ngày mới lên dc nhiêu đây. share cho pa con soft GP-Pro EX Ver. 2.7 new trên Mediafire.
disc 1
http://www.mediafire.com/?0vl9mdigmxaol7t
http://www.mediafire.com/?lxf578lgdxnzvin
http://www.mediafire.com/?tlf0of4k19xane4
load 3 files trên về xong , bạn cần load thêm http://www.mediafire.com/?dn4q92chgobl952 và chạy file này nha.
còn disc2 thì chưa upload xong.
			Bài viết của "CongTu.Bui" đã được cám ơn bởi các thành viên:
				Thành viên cấp 5
							Cảm ơn anh nhiều, tôi chưa load về. Nhưng cho hỏi, khi cài có hỏi key, code gì không pác?
							ah quên mất......thanks
key trial nhé
key trial do pác ibmacer cung cấp nè http://www.mediafire.com/?urjjl07bug0jydi
CongTu.Bui
  mình đã down về thử vài lần mà khi giải nén bung ra đều bị báo lỗi "crc..." bạn có thể up lên mediafire với định dạng file rar được không. cám ơn bạn
hhnhmln
 Down đủ 6 part về rồi dùng phần mềm Hj- Split ghép lại file thử xem thế nào nha bạn: http://www.taiphanmem.org/download-h...hanh-nhat.html
				Múi giờ GMT +7. Bây giờ là 07:33 PM.
