labview
em không hiểu lắm! anh co thể chỉ rõ cho em biết dược không?
Ý mình là bạn tìm cái đoạn dưới, mở theo cách của nó xem có được không
Function description
A new MP 277 Touch project was created for this procedure. You can also use an existing WinCC flexible configuration. The operator panel you use must support the objects etc. used in the global library.
Brief description
Open the global library in which the objects are located and which you wish to transfer to WinCC (TIA Portal).
Insert all the required objects into an existing picture or pictures.
Migrate the WinCC flexible configuration to WinCC (TIA Portal).
Open the migrated project in WinCC (TIA Portal).
Open the global library of WinCC (TIA Portal).
Insert the objects in the pictures into the global library of
WinCC (TIA Portal).
Múi giờ GMT +7. Bây giờ là 06:26 PM.
