				Thành viên cấp 6
					Bộ chuyển đổi USB<--->RS485 (Giao tiếp Upload/ Download PLC S7-200 được luôn)
							Bộ chuyển đổi USB sang RS485, hình dáng nhỏ gọn như Flash Disk USB. Giao tiếp ổn định, dùng download/ upload cho S7-200 cũng được luôn (không muốn nói là quá tốt).
 Driver hỗ trợ cả WIN 7 nên anh em cứ yên tâm về OS mà thiết bị hỗ trợ.
 Bảo hành 12 tháng ( 1 đổi 1).
 Thông tin tham khảo thêm:
 U-485:Mini USB to RS485 converter,only flash size, RS485 is the terminal,baud rate 300 bps ~1Mbps
 Description:
 U-485 is the USB to RS485 converter. The power supply of the product is from the USB port, and no need external power. Use the unique zero-delay automatic sending and receiving conversion technology and baud rate adaptive technology. Plug-and-play, suit for all software, and have the transceiver control. And it's in the high resistance state when not sending data.,support multi-point communication, which is different from other similar cheap products in market. There is  built-in anti-static anti-lightning circuit in the product. This product with sending/receiving indicator is only flash size.
 Features and technological index:
 1) USB port provide power, no need other power supply
 2) Output is terminal 2 wire half duplex RS485 port
 3) Wire should be over 0.5mm 2  in Cross-sectional area shielded twisted pair
 4) Max communication distance is 3000M(4800bps), 2000M(9600bps),
 1000M(115.2Kbps)
 5) Max communication network is 32 points
 6) Communication speed is 300bps~1Mbps
 7) Support UART: Data position 5,6,7,8. Stop Position: 1,1.5,2. Comparison Postion:
 odd/even/mark/blank/no parity
 8) Surge protection: Can withstand up to 600W voltage surge, protection from static
 voltage and thunder
 9) Installation method: 35mm standard din rail
 10) Working temperature: -20 to 70C
 11) Size: 65X22X12mm
 Hardware Installation:
 Hình ảnh sản phẩm:
 Giá bán: 800.000/cái
					Email:  Hidden Content
Tel: 0989.999973
				Múi giờ GMT +7. Bây giờ là 11:23 AM.
