Kết quả 1 đến 8 của 8
Chủ đề: Cp5512
Hybrid View
  1. #1
    Aug 2011
    52
    0
    0 lượt trong 0 bài viết
    Cp5512
    mấy anh ơi CP5512 dùng để làm gì vậy máy anh
  2. #2
    Thành viên cấp 6
    Jul 2011
    629
    8
    79 lượt trong 61 bài viết
    Tham khảo em nhé
    Laptop ExpressCard PROFIBUS Communication Card
    Introduction:
    Nowadays the laptops have eliminated the PCMCIA slot,but adopt the ExpressCard slot.So we especially develop the CP5512E for ExpressCard laptop.
    The function of our CP5512E is the totally same as Siemens original CP5512 except they use on different laptop interfaces.It’s the isolated PROFIBUS/MPI/PPI/FWL communication card specially for laptop, use iCoupler Magnetic Coupling isolators to replace the optocoupler,with small dimension, wide temperature range,and have anti-lightning and surging protective circuit and resumption of Overcurrent protection circuit on the RS485 interface, all use industrial IC in order to apply to wider temperature range, is used to achieve PROFIBUS/MPI/PPI/FWL communication connection between laptop and SIMATIC.
    CP5512E also can be used on PCI-E slot of desktop computer after the PCI-E to ExpressCard converter, the function is same as Siemens CP5611,CP5621.
    CP5512E support hot plug and plug and play. Perfect isolation circuit and interface protective circuit make you at ease to use it.
    Communication service:
    PROFIBUS-DP master station class 1 and 2
    PROFIBUS-DP slave and SOFTNET-DP slave
    S7 communication with SOFTNET-S7
    S5-compatible communication (SEND/RECEIVE based on the FDL interface) with SOFTNET-D or SOFTNET-S7
    CP5512E is suitable for the following version or above version softwares:
    STEP7 V5.2
    SOFTNET-S7 V6.1
    SOFTNET-DP, SOFTNET-DP slave from V6.1
    STEP 7-Micro/WIN from V3.2 SP4
    ProTool®, ProTool/Pro® V6.0 SP2
    NCM PC from V5.2
    SIMATIC PDM V5.2 SP1
    Technical Specification:
    Transmission rate: 9.6Kbps~12Mbps,the corresponding largest communication distance accord with PROFIBUS standard.
    Interface:connect PROFIBUS/MPI/PPI,isolated 9 pin Sub-D connector.
    Isolated voltage:1000VDC
    Interface protection:have anti-lightning and surging protection(Ipp=100A 10/700us,4KV) on the RS485 interface.ITU-TK20/21,VDE 0433 standard. ±15KV ESD protection. Overcurrent protection with restoration function:RS485 port can withstand up to 60V voltage caused by continuous over-current.
    Standard working voltage:3.3 VDC
    power:1.0W
    working temperature:-20~+75℃
    size:adapter:length* width * height(mm):123×68×30,cable length: 25CM
    weight:150g
    Support hardware of CP5512E:
    It’s different from PC Adapter and PC Adapter USB, CP5512E supports much more hardwares,such as Siemens S7-200/300/400PLC, PPI/MPI/PROFIBUS interface of touch panel, EM277,ET200 and other hardwares with PROFIBUS/MPI/PPI/FWL interface.
    It need PROFIBUS cable or MPI cable(Siemens part nr 6ES7 901-0BF00-0AA0) when CP5512E communicates with fieldbus devices.
    Tel: 0989.999973
  3. #3
    Thành viên cấp 6
    Jul 2011
    629
    8
    Em vào đây tham khảo thêm:
    http://support.automation.siemens.co...00&caller=view
    Tel: 0989.999973
  4. #4
    Aug 2011
    52
    0
    anh có thể cho em biêt vậy phải lam sao mới kết nối được với laptop không anh em thấy laptop em không có chổ nào căm vô hết ak anh làm ơn giup em tí nha a
  5. #5
    Aug 2011
    52
    0
    mấy anh có cái driver car cp5512 không cho em xinh đi em vào trang siemens download ma em không download được
  6. #6
    Nov 2011
    490
    0
    49 lượt trong 35 bài viết
    ^_^ cái đó chỉ dùng cho lap có khe pcmcia thôi, các lap sau này không có khe đó thì không dùng được, và nó không có driver rời, cài step 7 vô là nó tự nhận luôn
    HỌC, HỌC NỮA, HỌC MÃI,HỌC HẾT LỚP BẢY THÌ NGHỈ
    Aug 2011
    52
    0
    ak thì ra là vậy em hiểu rồi mà niếu như mình có khe pcmcia thì mình sử dụng sao vậy anh
  8. #8
    Thành viên cấp 6
    Jul 2011
    629
    8
    Trích dẫn Gửi bởi hanhphuong8h Xem bài viết
    Gắn vào đi rồi Teamview nha, mọi chuyện đơn giản mà.
    Tel: 0989.999973
