Các anh chị giúp m lỗi này với ạ !
Em check lỗi thì thấy báo thế này mà em ko biết lỗi chố nào các a chị chỉ cho em với ạ .
MAIN (OB1)
Network 7, row 1, col 1: ERROR 57: (operand 2) The literal/constant type is not legal for the instruction operand.
Network 7, row 1, col 2: ERROR 57: (operand 2) The literal/constant type is not legal for the instruction operand.
Network 7, row 1, col 3: ERROR 36: (operand 1) The size or data type is not valid for the instruction operand.
Network 7, row 1, col 3: ERROR 36: (operand 6) The size or data type is not valid for the instruction operand.
SCALE (SBR4)
Network 1, row 1, col 3: ERROR 36: (operand 1) The size or data type is not valid for the instruction operand.
Network 1, row 1, col 3: ERROR 36: (operand 2) The size or data type is not valid for the instruction operand.
Network 1, row 3, col 3: ERROR 36: (operand 1) The size or data type is not valid for the instruction operand.
Network 1, row 3, col 3: ERROR 36: (operand 2) The size or data type is not valid for the instruction operand.
Network 1, row 5, col 3: ERROR 36: (operand 1) The size or data type is not valid for the instruction operand.
Network 1, row 5, col 3: ERROR 36: (operand 2) The size or data type is not valid for the instruction operand.
Network 2, row 5, col 3: ERROR 36: (operand 2) The size or data type is not valid for the instruction operand.
Network 2, row 5, col 3: ERROR 36: (operand 3) The size or data type is not valid for the instruction operand.
MBUS_INIT (SBR1)
Network 29, line 16, ERROR 33: (operand 1) Undefined global symbol or local variable for the instruction operand.
Network 29, line 17, ERROR 33: (operand 1) Undefined global symbol or local variable for the instruction operand.
MBUS_SLAVE (SBR2)
Network 4, line 9, ERROR 67: The number of operands does not match the standard instruction signature.
Network 59, line 2, ERROR 67: The number of operands does not match the standard instruction signature.
Rất mong được các anh chị giúp đỡ !
sai kiểu dữ liệu khai báo nhé, số thực R mà
Em sửa kiểu dữ liệu rồi nhưng cái Modbus nó vẫn báo :
MBUS_INIT (SBR1)
MBUS_SLAVE (SBR2)
Lỗi này sửa thế nào ạ ?
#x2, #x1 ... em lấy ở đâu - nó đang báo lỗi chỗ đó gửi code lên đây xem nào
code này bạn viết hay copy ở đâu - khi bạn sử dụng modbus init và slave nó cần thêm ra các sub và ngắt theo hàm thư viện có sẵn, theo mình thây của bạn đang thiếu nhé
Múi giờ GMT +7. Bây giờ là 02:41 PM.
